New Member
Brightbox wireless client settings
Hi there, i'm having problems using my new EE Brightbox to connect to my
Raspberry Pi using the XBMC remote app. My setup was working perfectly with two Netgear DGN1000 routers and is now broken when using the new Brightbox access point, however it still works from the DGN1000 being used as a repeater. I've tried opening the ports and disabling the firewall with no luck.
I can connect to the Raspberry Pi when accessing via a wired connection so i'm wondering if there is a setting that's stopping communication between the wireless device (iPhone) running the app and the Raspberry Pi connected by ethernet
Recent solutions
Subject
989
0
5968
1
10582
0
2015
1
