Highlighted
by Contributor
Brightbox 2 connection issues
hopefully I can find some clarity to my problem in here, basically router is saying it is connected to the internet, I've checked the router itself and all the lights are green and I've logged into the router and it is showing an active connection, but as far as loading anything goes nothing happens. Can anybody please shine a light on this issue?
14 REPLIES 14
Highlighted
by Investigator
Re: Brightbox 2 connection issues
The same thing is happening to me. It's really annoying
Highlighted
by Contributor
I don't know how long it's been like it but I only noticed it when I went to play a game on my PlayStation and it said it couldn't connect to the PlayStation server! This is the first time this has happened so hopefully it's just some maintenance or something.
Highlighted
by Investigator
That is exactly what happened to me mate
Highlighted
by Contributor
Fingers crossed it's all sorted by the morning I'll post in here if anything changes.
Highlighted
by Investigator
dns servers are down. looks like nationwide and i guess EE are working on it. you can set your dns server in your network connection to 8.8.8.8 (googles dns) as a workaround until EE fix things
Highlighted
by Contributor
Thanks for the response I did wonder if something was down as this is the first time I've had something like this happen, hopefully it all gets sorted soon
Highlighted
by Investigator
How would I change the dns to 8.8.8.8
Highlighted
by Investigator
on a pc using windows 7 i go to network and sharing center, then click adapter settings at the top left then the properties button, then double click "internet protocol tcp/ip v4" and finally there you have an option that says preferred dns server that you can fill in.
I set the primary ip address (the first line) to the address of my router (default is 192.168.1.1  i think) and the second line to 8.8.8.8.
sorry if this is confusing.
otherwise  if this is taking a while to get fixed, or you've got multiple devices then as a last resort you could log into the router and go to advanced and change the option for DNS IP address instead of "obtain from isp" to "manual" and then fill in 8.8.8.8  BUT .. you have to remember to change it back when things are fixed and it's not good from a security aspect i believe.
Highlighted
by Investigator
 I'm a little confused but I appreciate the help. I'll just wait and hope it's fixed soon but if not then I'll wait until tomorrow. I wish everyone luck. 😀
Highlighted
by Investigator
i reckon there will be a lot of people complaining and a few stressed out IT engineers on the case. If youre not comfortable changing the settings and can wait, then it seems a smart move to let EE sort things.
All the best
Highlighted
Why bother? It's probably more reliable & you don't want this to keep happening.
Highlighted
by Investigator
fair comment XRaySpeX
Highlighted
Good Morning to you all.
We're aware of an issue affecting broadband services this morning - we're working to get this resolved as quickly as possible.
Can you try turning the power off and on and seeing if this resolves this for you? As this has worked for some users.
Thanks, Leanne.
Highlighted
by Contributor
Mine is up and running again, sometimes the best thing to do is just to leave it and hope for the best.
