Highlighted
by Investigator
Brightbox 2 MAC filtering fail
To combat some recent home network intrustions I wish to enable MAC filtering.
After entering the various MAC addresses in the advanced settings and selecting enable I found all access was blocked - even for deveices on the list. Any ideas on trouble shooting this?
My box is running firmware: v0.03.06.0001-OT (Mon Dec 5 15:19:29 2016)
Apart from changing passwords and turning off DHCP (I have a raspberry pi doing that and stuff) the box is standard config.
Highlighted
by Investigator
Solution
Re: Brightbox 2 MAC filtering fail
Ok I have had some luck.
After adding another address my router froze. So reboot and reset all the MAC filtering.
I built this out again slowly checking as I went. This time it seems to be working. But having used 28 of the 32 slots I might be turning this off.
Thanks for the guidance, and checking it works. Seems like I just needed a good old reboot.
Highlighted
Hi @AnotherCustomer,
Welcome to the EE Community.
Have you followed the MAC filtering guide on the firewall features help article?
Highlighted
Just to test it for you I enabled my PC to MAC Filter. My PC continued accessing the Net but my mobile didn't. When I disabled the MAC Filter both could access the Net.
Are you sure you've got the MAC addys correct? There's a drop-down list at the bottom of MAC Filter to select them.
Highlighted
by Investigator
Solution
Highlighted
EE Employee
I'm glad you are getting sorterd @AnotherCustomer
Many thanks,
Lee
Highlighted
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
