Highlighted
by Valued Contributor
Valued Contributor
App has ceased to work on my Nexus 7 tablet
The MYEE app was working fine until recently on my Nexus 7 Tablet but has now stopped working and the updated app is "Not Compatible" with your device.
Why break something that was fine? It's not as if the Phone app is any better than it used to be. Smiley Frustrated
Highlighted
Solution
Re: App has ceased to work on my Nexus 7 tablet
@aldaweb  with Wifi off on the device click THIS and it will show what data you do have left.. don't forget to save it as a bookmark for future use.
7 REPLIES 7
Highlighted
@aldaweb  Until EE make it compatible with tablets you've always got the website that you can log into after all a tablet is not a phone and that's what the app is aimed at at the moment.
Highlighted
Valued Contributor
Thanks @Chris_B but I am using 90 day data SIMs and I currently cannot get the balance from the website either. I have never had to register this number and since it only has a day or 2 left before I change it for another I don't intend to now.
I guess it's back to Three or giffgaff for my data SIMs
Highlighted
Solution
Highlighted
Valued Contributor
Thanks @Chris_B I'll check it when I get back from work tonight.
Highlighted
Highlighted
Text AL to 150 to see balance & allowances remaining.
Highlighted
Valued Contributor
That worked fine though I only had 31 mins left. time to get a new SIM
