Highlighted
by Investigator
Anyone having issues with android os taking up a lot of mobile Data
Anyone noticed their phones data being eaten up by 'android OS' mines taking up 10 time more then usual.
11 REPLIES 11
Highlighted
Re: Anyone having issues with android os taking up a lot of mobile Data
Can you give a bit more info such as:
  • Your phone
  • Your plan
  • What version of Android are you using
Also have you factory reset your phone recently?
Have you checked out your Data usage app to establish what apps are using data?
Highlighted
by Investigator
Hi Northerner
I have the Sony Z5 Premium
I've also got what I believe to be the latest version of Android (7.1.1)
I'm allocated 5 GB,  which I normally use about 4 GB's of most months.
I don't really want to factory reset unless it's the last resort.
I'm using the data usage report that you can read within the settings
Highlighted
EE Employee
Hi @Tommaccy and welcome to the community.
I would double check all the apps and make sure you only allow the ones you need to have data.
Many thanks,
Lee
Highlighted
by Investigator
Read more
I can't disable android os.  All the other apps are using the same amount. I want android os not to use as much, all the other amounts are fine 🙂
Highlighted
Try these Settings:
  • Settings / Connection / Data Usage / Menu button / Restrict Background.
  • Settings / More / About Device / Software Update / WiFi Only.
Highlighted
by Investigator
My updates are set on WiFi only,  and I've recently restricted background data. Unfortunately,  neither has helped my problem I'm afraid.
Highlighted
EE Employee
Hi @Tommaccy
It maybe worth popping over to the Sony support pages as you may be able to gain further information in regards to the software.
Many thanks,
Lee
Highlighted
by Brilliant Contributor
Has this only happened after an update?
If so then factory reset the phone.kt is always advised to factory reset after major updates at least.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
by Investigator
I really don't want to factory reset my phone, but it looks like it's my only solution 🙂
Highlighted
No one wants to but if you back up you will be fine.
I don't know about Sony but when I back up my S8+ on my Smart Switch it restores it back to the way it was. Background, page layouts and all.
Highlighted
Morning @Tommaccy
Thanks for coming here,
Let us know how you get on 🙂
