APN codes - T-Mobile pay as you go
Does anyone know if the APN codes for T-Mobile are different for pay as you go?
I can't get any apps to work on 3G (other than Mail and Spotify) on my jailbroken iPhone 3GS. Any help gratefully received.
EE Employee
Re: APN codes - T-Mobile pay as you go
Hi buftontufton
Here are the APN settings that you'll need, Let us know how you get on Man Happy
Access Point Name = everywhere (case sensitive)
Username = eesecure
Password = secure
Barry
Community guidelines Community stars programmeMeet the EE Community teamHow to use the community
[ Edited ]
Nope, still doesn't work. I may have to go back to O2 at this rate.
EE Employee
Did you try hooking it up to iTunes to update the carrier settings?
I ended up hard resetting the network settings, which worked. Kind of using a sledgehammer to crack a nut, but got there in the end.
Thanks for the help anyway! Much appreciated.
