Highlighted
by Investigator
5GHz does not show up in the WiFi networks lists of any devices
5GHz band SSID does not show up in the WiFi networks lists of any devices. I tried restart router,reset to factory settings but no luck.
14 REPLIES 14
Highlighted
by Investigator
Re: 5GHz does not show up in the WiFi networks lists of any devices
Never had a problem with bt router.
Highlighted
Then devices are 2.4 GHz band only.
Highlighted
Is it activated on the router under the settings?
Are you close enough to the router?
Thanks,
Highlighted
by Investigator
Yes is activated on settings and I'm close enough to router. I can find
5GHz WiFi on my bt router when I tested.
Highlighted
Hi @alius,
Welcome to the EE Community.
What type of devices are you trying to connect?
Have you checked they are 5GHz compatible?
Is it a Bright Box 2 router?
Highlighted
by Investigator
Yes it is bright box 2 router,3 android phones and tablet can't find 5GHz WiFi, was no problems with previous router.
Highlighted
Do the router's 2.4 GHz & 5 GHz bands have distinct SSIDs? By default Brightbox 5 GHz SSiDs are prefix by "5GHz-" . I've heard that BT HHs use the same SSID for both bands & some devices have trouble with that.
Highlighted
by Investigator
Highlighted
Can't see image. Can't you just say "Yes" or "No"?
Highlighted
by Investigator
Yes
Highlighted
Thanks for helping @XRaySpeX
Do you have any further suggestions for @alius
Thanks, Leanne.
Highlighted
I notice 1 discrepancy:
My 5 GHz Mode is also A+N+AC but Above & Bandwidth are greyed out & I can't get them to show.
Highlighted
by Investigator
Update: this morning my phone found 5GHz singal,but unfortunately it's gone again after few minutes. I think router is faulty it self.
Highlighted
Sounds likely. Phone CS & ask for a replacement, cuz it don't work on 5 GHz band.
