Highlighted
4gee action cam, what's the maximum micro SD card storage i can fit in please
what's the maximum micro SD card storage i can fit in it please
Highlighted
Solution
Re: 4gee action cam, what's the maximum micro SD card storage i can fit in pleas
It tells you in the user manual:
Note: The camera supports microSD cards (formatted in FAT32 only) up to 64 GB in size. You can purchase a microSD card separately from an EE store or online.
Highlighted
Solution
Highlighted
Highlighted
thanks, i dont know which manual says it because everything in the box didnt mention it
Highlighted
No worries @aminazen
At least you know now.
Richard
