Highlighted
by Investigator
4g mini wifi not working
Hello I have a 4g mini wifi box that has been working fine for months, recently said box has stopped working it does full bars of signal but the 3G light is flashing on and off, I can connect to the box but cannot access the internet, Ye plan has 30gb of data each month and I have not used it at all this month, any help would be gladly appreciated.
Many thanks luke.
6 REPLIES 6
Highlighted
Re: 4g mini wifi not working
Have you looked at the Connection status inside the MBB device?
Highlighted
by Investigator
Hi ray thanks for the reply I'm not to savvy with technology could you please explain to me how I check the connectivity inside the mbb device.
Highlighted
Login at http://192.168.1.1 as admin/admin & look for Connection or WAN or Status.
Highlighted
by Investigator
I've managed to log on and check connection and it just says 'connecting' no matter how long I stay on the page it fails to connect, have you any ideas as to what is happening here ray?
Highlighted
No. Just reboot it & keep an eye on the status.
Have you checked coverage in your area & any problems there?
Highlighted
Hi @Bodz101
Welcome to the community.
Further to @XRaySpeX advice, you can check the status of your area on our network status checker.
Let us know how you're getting on.
