Highlighted
by Contributor
4GEE Home Router blocked access
Bought 4GEE home router from EE due to restricted broadband speeds with my current provider (BT), however when trying to stream content it doesn't work.
BT Broadband works but stutters due to low speed. EE 4G on my phone works perfectly so definitely the EE router. Both content lock and over 18 lock are are set too off and I can’t find an overall firewall off button in the settings.
Anyone any ideas?
20 REPLIES 20
Highlighted
Re: 4GEE Home Router blocked access
Does any browsing or email access work?
Is it on PAYG or contract?
What does it tell you about your data when you go to http://add-on.ee.co.uk/status ?
Can you login to it at http://192.168.1.1 ?
Highlighted
by Contributor
Browsing and email both work  fine.
It is 18 month pay monthly.
currently have 88gb of 100gb left.
Yes, i logged on there to change content lock settings but still no luck.
Highlighted
You don't login to router to change Content Lock but follow Switching Content Lock on or off .
What site(s) can't you get to?
Highlighted
by Contributor
Spoke to EE on the phone who have confirmed all content lock is off.
GSE IPTV app.
Highlighted
EE Employee
Hi @c7ndo and welcome to the community.
Are you having any issue getting onto any other sites?
Many thanks,
Lee
Highlighted
by Contributor
No everything working fine exept when trying to stream.
Highlighted
EE Employee
Hi @c7ndo
Do you have any issues when streaming Netflix or Youtube?
Many thanks,
Lee
Highlighted
by Contributor
Both working fine, only problems with IPTV.
Highlighted
EE Employee
Hi @c7ndo
Just so we can rule out any device issues, please can you pop your router SIM in your phone and test the opposite as well.
Many thanks,
Lee
Highlighted
by Contributor
Router sim in my phone, IPTV working on 4G.
Phone sim in router, IPTV not working not working on wifi.
Highlighted
Hi @c7ndo,
What type of device are you connecting to the 4GEE router when streaming?
Highlighted
by Contributor
Good afternoon,
An IPTV set top box (MAG322) connected to my tv and my iPhone through the GSE IPTV app. Both not working when connected to router.
Highlighted
Hi @c7ndo,
I've sent you a private message.
Highlighted
by Contributor
Spoke to technical team who are putting it down to the router unable to provide a static IP.
no solution found.
Highlighted
Don't believe that! A streaming app does not require any client to have a static IP. Static IPs are only needed when a server wants to make an unsolicited connection to your device. In this case you are asking the server to connect to you & it is responding to your request.
If that were true you wouldn't even be able to browse Amazon.
Highlighted
EE Employee
Hi @c7ndo
What happens when you use your phone as a hotspot and connect the MAG box to it?
Many thanks,
Lee
Highlighted
by Contributor
Hotspot works as normal when not connected to the Wi-fi. Everything is pointing towards some setting on the router but I’ve tried everything I know of and getting no where.
Highlighted
Hello, i am having the same problems, can you send me a private message please, xxxxxx@xxxxxxxx
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
Highlighted
by Contributor
Private message sent.
