Highlighted
by Investigator
4G not working
Hi all,
Iphone 6 - recently upgraded to a SIM only 4GEE contract and yesterday my 4G just suddenly stopped working. It still says I have 4G signal yet nothing will load, run etc when I am using 4G - it's just appears to be continually loading. There are no issues in the area as my girlfriend is having no trouble with her 4G.
any ideas?
cheers
Adam
Highlighted
by Profile closed
Not applicable
Re: 4G not working
@adambailz Try a network reset by going to Settings>General>Reset>Reset Network Settings, follow the prompts and your iPhone will then reboot.
You will just need to then re-enter any previously saved WiFi passwords but no other user data will be lost.
Highlighted
by Investigator
Re: 4G not working
Hi thanks for your reply. Have tried this and had no luck unfortunately
Highlighted
Re: 4G not working
Hello there @adambailz
Thanks for coming here.
Is this happening for all websites and apps?
Is your girlfriend also on EE?
Thanks 🙂
Highlighted
by Investigator
Re: 4G not working
Hi there
yes happening for everything. She is also on EE
thanka for any help you can give!
Highlighted
Re: 4G not working
Hi @adambailz
Thanks for coming back to me.
Are you able to try the SIM card in her device to see if you can access the internet?
Let me know how you get on 🙂
