by Violatior89
4G not working in apps and running very slow
Re: 4G not working in apps and running very slow
Are you in a good 4G area?
Can you add a bit more information, such as your phone, if you are PAYG or pay monthly.
  • You can check your coverage here.
  • You can check your local mast for issues here.
by Violatior89
Galaxy S7 edge
Pay monthly
According to ee no network problem in my area. Im using data to reply. Works fine on ee sight just nothing else
Hello there @Violatior89
Welcome to the community,
How long has this been happening for you?
Is this certain apps that are running slow?
Thanks 🙂
