by Anne46 Contributor
4G is not showing on my Samsung phone
Up until today 4G was showing on my Samsung A5 phone, it has disappeared.  When I go to Mobile Networks under 'Network Mode' it just shows: LTE/3G/2G (auto connect), 3G/2G (auto connect), 3G only, 2G only.
by Brilliant Contributor
Solution
Re: 4G is not showing on my Samsung phone
@Anne46wrote:
I've discovered what's happening. I switch wifi off at night, when I switched it off last night the 4G ligo showed, when I switched wifi back on this morning the 4G logo disappeared. Having said that the 2 little arrows are showing but without the 4. It's odd though as previously my phone would have the wifi and 4G logo showing at the same time.
Have you turned off download booster off as this would show both.
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.0)
12 REPLIES 12
LTE is just another term for 4G.
Did you have a software update today?
Between Android 6 and 7 Samsung changed what it said from 4G/3G/2G to LTE/3G/2G
I meant 4G isn't showing at the top of the screen next to the wifi 'icon.' (Though I didn't know LTE was another name for 4G). I know sometimes if reception is poor it won't be there but I've never had the problem at home before. Currently I have 2 bars showing for reception and still no 4G.
Check the network status page. There may be an issue with the last at your home address.
Hello there @Anne46
Thanks for posting on the community.
Do we have any network problems showing in your area?
If not, can you try rebooting your phone and see if this works for you?
Speak soon, Leanne 🙂
Mobiles when on Wifi do not usually show the mobile signal type & strength except for the 1st few secs. it takes to connect to WiFi.
Solution
Not intentionally, I've never heard of download booster. Where do I access it?
I found download booster, it was off. I've switched it on now and 4G is now showing. Thanks.
Glad to have helped 🙂
Glad you got the help you needed @Anne46
Come back to the community anytime 🙂
