Highlighted
4G and 3G
I have recently recived my EE 4GEE sim in the mail, when i have enough service for 4G it works perfectly fine and everything loads normally, when it is on 3G nothing loads at all. its the same as having the mobile data turned off
9 REPLIES 9
Highlighted
by Ace Contributor
Re: 4G and 3G
@PipFarden
4G vs 3G: What's the difference
because 4G is faster than 3G same as home broadband if you have fiber broadband that will be faster than normal broadband.
 Many Thanks
Highlighted
Re: 4G and 3G
@PipFarden   What device do you have and have you got it set to connect to 4G only ?
Highlighted
Re: 4G and 3G
No, 3G does not work at all for me, nothing ever loads on it. On every App it says "no internet connection"
Highlighted
Re: 4G and 3G
I have the Iphone 6 and i dont know, how do i change it?
Highlighted
Re: 4G and 3G
@PipFarden   This is simple with this device as it does it for you and you have nothing to set on it.   But you can check just to make sure your using calls and data over 4G.
go to Settings>Mobile data>Mobile Data Options>Enable 4G and then set it to Voice and Data.
Highlighted
Re: 4G and 3G
@Chris_B yes, i have it set on voice and data. it has been set on this the whole time. Whenever i turn on my mobile data it is on 3G, sometimes i get 4G. When on 3G it says "no internet connection" on all of my apps. when on 4G everything works perfectly
Highlighted
by Profile closed
Not applicable
Re: 4G and 3G
Try performing a network reset by going to Settings>General>Reset>Reset Network Settings, follow the prompts until your iPhone reboots.
Highlighted
EE Employee
Re: 4G and 3G
Hi @PipFarden and welcome to the community.
If you are stilling having any issues after following advice from fellow forum users please do contact customer services.
Many thanks,
Lee
Highlighted
Re: 4G and 3G
@PipFarden  It might be worth having a look at THIS as there could just be a mast issue in your area.
