by squirrelred Established Contributor
1571 voicemail
I would like to personalise the message on 1571.  I see that someone asked this a while ago and did not get a solution.   Does anyone know if it can be done?
Re: 1571 voicemail
Try dialling 1571-2-1 to leave a personal greeting. That's how it's done on BT. EE's anybody's guess.
Re: 1571 voicemail
Thanks alas does not work.. probably only BT customers.  All I can do is listen to a standard greeting and received messages.  Perhaps I'll try contacting ee helpline.
Re: 1571 voicemail
If it's not on the menu, it won't be there.
Re: 1571 voicemail
Hi @squirrelred
If anyone will be able to help, it'll be the customer service team.
Give them a shout and let us know how you get on.
