by youngbegby
unregistered silent voicemails
hi there, I’m receiving about 6-8 voicemals a day, all silent, no registration at all, so can’t track them back,  no other clues ...all help welcome!
Re: unregistered silent voicemails
Hi @youngbegby
Welcome to the community. 🙂
What is it that you're looking to do?
Are you looking to find out who called you?
Did you receive any missed calls or voicemail notifications?
Look forward to hearing from you.
by youngbegby
hi there; I’m looking to stop them; there’s no sign the calls are there unless i have a genuine voicemail (indicated on my screen) and on access to vm then have to wade through 6-8 calls to get to the real ones..
This is really unusual, @youngbegby.
Usually, you would get a missed call through the device and (if set up through calling your voicemail) a separate text message advising that you have missed a call, a number and whether they left a message.
If this isn't the case, I recommend speaking to our technical support team.
They'll be able to help.
