by shellbell
iPhone 7 headphones not working after couple of uses?
Upgraded to iPhone 7 start of June and headphones not working, only used 2 or 3 times.
Used to make a call last week and told it sounded like I was under water? Used again at weekend listening to music, took left bud out of ear whilst in a shop and realised that the sound on the right side is coming and going.
Will EE replace or is this an Apple issue?
Re: iPhone 7 headphones not working after couple of uses?
@shellbell  make sure nothing is in the lighting port.  fluff etc etc.  turn off the device to check this .     if this ok you need to book an apple appointment to get apple to exchange these.
by shellbell
Thanks Chris!
Hi @shellbell,
Welcome to the EE Community.
That's great advice from @Chris_B. Your local Apple store will be happy to help.
Recent solutions
