by Kylechapman19
calls dropping when on a phone call
my calls keep dropping on phone to friend at 8:29.The  called dropped on me,i was wondering if anyone else is facing the same issue with calls dropping and internet being slow.
by Ace Contributor
Re: calls dropping when on a phone call
Has this just started happening?
Have you experienced this in other areas?
Pop your postcode into the service checker, and see if it reports any issues etc in that area.
EE service checker
