Highlighted
battery usage by apps
hello, where i can find the list of using battery by apps? thanks 😉
Highlighted
by Ace Contributor
Solution
Re: battery usage by apps
hi @ginitume. It's under settings / battery.
Any questions, ask away!
Highlighted
by Ace Contributor
Solution
Highlighted
thanks for the quick response😁
