by Raffaello2017 Established Contributor
Why is my iPhone battery charge only lasting about 4 hours
Why is the battery charge on my iPhone 11 Pro suddenly only lasting about 4 hours ?
Solution
Re: Why is my iPhone battery charge only lasting about 4 hours
@Raffaello2017  Have you tried resorting the device to factory settings?    Back it up first then restore it but do not restore from that backup until you’ve tested it for a few days.  If all is good after this try restoring from that backup and see how it goes.  If you have issues after this you’ll need to restore again as you’ve put something back on the device that is causing this.
you could look in Settings>Battery and see if something is using a lot of battery power.
Solution
