by G-NIOG Investigator
Why doesn't snapchat work on my data?
Snapchat (and other certain apps) refuse to work on data- I've been through my phone with a fine-toothed comb and set all switches regarding usage of data to allow
Solution
Re: Why doesn't snapchat work on my data?
@G-NIOG   I don't think this work but it's worth a go have you tried a network reset on the device? If not navigate to settings/General/reset/reset network settings.   You will need to put your Wi-Fi passwords back on the device after this and that is the only thing that you lose on the device when performing this action.
12 REPLIES 12
@G-NIOG   Are there any updates for these apps ?
Yes, I've also tried uninstalling and reinstalling the apps
The latest iOS (10.3.2)
@G-NIOG  It should be working as my daughter uses Snapchat without any issues over cellular data.
Just to check you do have data left in your allowance?
I have more than 3/4 data
Solution
Ok thanks I'll try that
Brilliant it works now! Thanks very much
EE Employee
Hi @G-NIOG
Glad you are now sorted.
Great work @Chris_B 🙂
Many thanks,
Lee
