by Im33 Investigator
Why do I have to keep updating the same apps every few days on my iPhone 6s Plus
Re: Why do I have to keep updating the same apps every few days on my iPhone 6s
Hi @Im33
Thanks for coming to community 🙂
I believe this is because the app manufacturers are constantly updating software versions for security and improvements to your experience.
Have you got the apps set to automatically download or manually download?
I have them set to automatically download so I don't get prompted any more.
To do this go into
Settings >>> iTunes & App stores >>> toggle Apps on.
Richard
It's not just one app. If I go on to the App Store it comes up with like 12 updates. I update them then the next day or a couple days later the same 12 apps need updating it's happened 3 or 4 times in the last month
by Brilliant Contributor
@Im33
As @Richard_C has stated this has nothing to do with EE, it is the developers of those apps that are constantly updating the app and fixing bugs.
App companies don't just make an app and then leave it. They constantly work on them to make them safer and better for the consumer.
It happens with all apps on Android or Apple
by Profile closed
Not applicable
If the same apps are showing updates time after time though, there does look to be some kind of underlying issue somewhere.
Occasionally apps get another update shortly after a previous update (usually when the developer hasn't tested the app properly and it crashes on some or all iOS devices) but generally app updates shouldn't be happening all the time.
Try deleting one or some of the apps which keep showing it needs an update and re-download it as that will download the newest version that is currently available.
What are some of the apps that keep requesting updates?
Also just try turning your iPhone off completely and then back on again as your app store may be stuck in some kind of loop.
@Im33. If your doing this on wifi are the apps updating fully before you come off wifi.  Have they installed fully?
