by NickH16 Established Contributor
Using my phone abroad next year
Honeymoon planned for July next year in Lanzarote. Will I be able to use my phone as normal with no costs with roaming on? As when I was with three it was all included and no costs as I was if I was in the UK
Re: Using my phone abroad next year
@NickH16  At present you can use any network abroad in the EU as if you was in the UK.
Ok great thanks. Just don’t want to be charged for calls/messages/data when over there
@NickH16 you can use up to 15GB per month while in the EU if your tariff has this or more.
You just need need to make sure roaming is enough on your account,  you can even do this now as it will not cost you anything to enable and you’ll be all set when you get there.
Just text ROAMING to 150.
Recent solutions
