Make your house a smart home - with help from EE
by AbbieA777
Starting up a contract
Hi there,,
i was searching on other sights and found a contact with EE on mobiles.com for the iPhone 8 which is £48 a mouth I was wondering if you have any better deals?
by Legend
Legend
Re: Starting up a contract
HI @AbbieA777
EE deals can be found in the shop area here.
by Expert Contributor
Expert Contributor
@AbbieA777 what do you get for £48 per month and what is upfront cost? EE don't price match
by Ace Contributor
You won't find it cheaper with EE direct but buying from mobiles direct won't give you all the benfits of buying direct from EE
Brendon (Android Expert)
Samsung Galaxy S8+ (Oreo 8.0)
@BrendonH  It doesn’t matter with the iPhone as you get all that is offered directly or indirectly.
by Ace Contributor
What including BT Sport and Apple Music etc?
