by Peterpea Established Contributor
Roaming on an eSim
I’m off to Malaysia in a couple of weeks... will my eSim work over there or will I need to convert back to a physical sim?
Solution
Re: Roaming on an eSim
Hi @Peterpea
It should work without a problem. Please ensure you have text ROAMING to 150 to ensure roaming is activated on your account.
Roaming costs and add ons for Malaysia can be found here.
Solution
Hi @Peterpea
