by Sarahchez18
Pinterest not working on 4g
I can't log in to Pinterest on 4g. It's permanently saying I'm not connected to the internet. Tried logging in via Facebook and this won't work either. I am using an iPhone. Any suggestions?
TIA
Solution
Re: Pinterest not working on 4g
@Sarahchez18  Is mobile data enabled on the device and have you allowed these apps to use cellular data?
Solution
Try changing your network down to 3G,
I have had similar issues today with the Halifax banking app and Amazon app. Shows 4G on my phone but won't connect.
by Sarahchez18
Sorted. Thanks for this.... why that was the only app turned off I don't know!! Appreciate your help 😃
Hi @Sarahchez18
Welcome to the community, it's great to have you on board. 😄
I see @Chris_B and @Northerner were able to help you sort this out.
Feel free to drop by again anytime.
Chris 🙂
