by Andrea1970
New Member
My phone is not ringing, it keeps going to voicemail
Re: My phone is not ringing, it keeps going to voicemail
Hi @Andrea1970
Try  deactivating voicemail and then restarting your device, then reactivate.
VM OFF to 150 to disable and VM ON to 150 to activate.
Hi @Andrea1970.
Can you make sure the Do Not Disturb feature is not active in your settings?
Does this happen with all numbers that call you?
Jon
