by HayleyDavis01 Investigator
My mobile data does not work when Off Wi-fi
Why is my mobile data not working?  Wi-fi is fine but for the last few days when not on Wi-fi and 4g should work it does not.
Wifi data is on!
Phone been turned on and Off as well still no joy.
8 REPLIES 8
Re: My mobile data does not work when Off Wi-fi
Are you in a 4G area?
Have you tried resetting your network settings ( settings - general - reset network settings)
EE Employee
Hi @HayleyDavis01 and welcome to the community.
Has the above advice helped at all?
Many thanks,
Lee
No sorry it hasn’t and my personal hotspot just seems to be constantly loading!
EE Employee
Nothing it tells me my mobile data could not be activated
@HayleyDavis01  Navigate to Settings>Mobile data and is te toggle at the top switched on ?  It should be green.     And while your there are the other toggles on below for your apps ?
EE Employee
Hi @HayleyDavis01
i would recommend speaking to our technical support team if the further advice given by @Chris_B has not helped.
Many thanks,
Lee
Yes thank you
