by Whataday36
New Member
My broadband strength is running slow
Re: My broadband strength is running slow
Which strength? Your WiFi or the BB connection?
1. Post your full router stats.
For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information.
