09-12-2018 08:43 PM
Looking into buying an Apple Watch series 4 & I want the Cellular option so I can use my watch to make calls, send text etc when I haven’t got my iPhone with me. Is GPS + 4G the same as GPS + Cellular? Does 4G mean I can use my watch without having my phone with me?
09-12-2018 09:08 PM
Yes, they mean the same thing. You are not looking to buy from another country though are you?
If so - don't as the cellular connection will only work in the country the watch was purchased.
09-12-2018 09:06 PM
@lottlott2002 Yes it’s the same.
Just to add your phone will need to be on even if it’s not with you to send text messages via the watch.
09-12-2018 09:08 PM
09-12-2018 09:17 PM
Not looking to buy from another country but useful to know. Thanks 😁
09-12-2018 09:19 PM
Thank you for responding 😁
Subject |
