by Matriarch Investigator
Iphone 7 not completing connection to BT router
Recently switched to BT broadband and the Iphone accepts the login details to WIFI (tick against the WIFI name) but the phone constantly displays the processing circle and remains on 4G. I have tried Forget This Network, Reset Network Settings, turning phone off/on, turning router off/on, checked the security type on the router is WPA2. Everyone else in the family connects to the router with Samsungs so it's not the router. It does connect to my daughter's WIFI. The phone has not been dropped or damaged. So is there some obscure setting I'm missing?
Solution
Re: Iphone 7 not completing connection to BT router
SOLVED
Solved it, so here it is for anyone in a similar situation. I have BitDefender mobile secutiry on my phone and part of that is VPN. Turned off the VPN and I was able to establish a connection to the home WiFi. I haven't tried it with any other WiFi networks or hotspots, but I now will manually connect to VPN when I'm surfing using 4G.
Thank you to those who tried to help me sort this.
7 REPLIES 7
Which BT router is it?
Hi @Matriarch
Welcome to the community.
Could you try resetting your network settings on the iPhone please?
Tap Settings > General > Reset > Reset Network Settings > Follow the on-screen prompts.
Thank you for your reply but I have already done that.
OK thanks, @Matriarch
Is your iPhone able to connect to different WiFi connections?
Is your software fully up to date?
Tap Settings > General > Software Update.
Apologies, not BT but Post Office (switched 2 weeks ago). The router has no markings whatsoever but the documentation states Technicolor Gateway. The WiFi specs are
Wireless Standard
802.11b/g/n 2.4 GHz and 802.11a/n/ac 5 GHz
Wireless
  • 802.11ac 5 GHz with 1.3 Gbps data rate
  • 802.11n 2.4 GHz with 300 Mbps
  • Wireless Protected Setup (WPS)
  • WEP data encryption (64/128 bit)
  • WPA/WPA2, WPA-PSK/WPA2-PSK
  • Wi-Fi scheduling
  • Multiple SSID (up to 4)
Does the router show 2 SSIDs? Have you tried connecting your phone to both of them?
Solution
SOLVED
Recent solutions
