by Wendyh68 Investigator
Iphone 11 pro
Hi, if I buy a new iPhone 11 Pro can I simply switch the sim from my iPhone 7 and the plan etc will continue to work as usual?
Solution
Re: Iphone 11 pro
@Wendyh68 : Yes, simple as that! They both take nano-SIMs.
Solution
Re: Iphone 11 pro
Re: Iphone 11 pro
@Wendyh68   The device you use will not effect your account or payment of your tariff.  You can even switch to a android device and it will not change a thing.
Re: Iphone 11 pro
Thank you, really appreciate your reply
Re: Iphone 11 pro
Thank you, I really appreciate your reply.
Re: Iphone 11 pro
You're welcome 🙂  . Glad to be of assistance.
Recent solutions
