by mst
I phone 5 works fine but in car via BT no signal code 21153
I moved from i phone 4s to i phone 5 with EE the phone works fine but when in my car via BT & paired etc a call shows no signal, error code 21153. but away from the car as normal the phone is OK. Maybe I am doing something wrong, any ideas?
Re: I phone 5 works fine but in car via BT no signal code 21153
Hi @mst
Welcome to the community.
What model car kit are you using?
Also, are you connecting via Bluetooth?
by mst
Hi the phone is connecting via BT in 2yr old ford ka+ which is SYNC,d OK, my previous i phone 4s worked perfectly. The same fault also occurs in another car.
@mst  Where did you get the iPhone 5 from as it sounds like the device has an issue with Bluetooth.
