by Lfoster16
I am unable to make calls whilst abroad says calls barred
EE Employee
Re: I am unable to make calls whilst abroad says calls barred
Hi @Lfoster16 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
by Lfoster16
No it’s not worked
Get Outlook for iOS
EE Employee
Hi @Lfoster16
Are you ok to receive calls/texts?
Many thanks,
Lee
