by Courtney111
How to keep my old number
by Ace Contributor
Solution
Re: How to keep my old number
Hi @Courtney111
Please click on link below.
https://ee.co.uk/help/help-new/getting-started-and-upgrading/keep-my-number/how-do-i-transfer-my-num...
You can find all information here that you need to keep your number.
by Ace Contributor
Solution
Hi @Courtney111
@Courtney111  If your upgrading you’ll keep the number as it’s an upgrade.
Are you upgrading ?
