by Nbird Investigator
Help with voicemail and contacting EE
Today I have had difficulty accessing my voicemails. So I pressed 1 or the voicemail button as always and EE automated messages now says I need to set up a pin to access my messages, and I have to do so from the U.K.  I am in the U.K.  Next step It says hold and press 1 and select option 3 - I do this and I get the same message I need a pin to access this. So it says if you need help call 150. I do that and again it just comes up call failed? I can't bypass this. Never had problems before and have never set up a pin before! But can't contact EE to sort either! Help!
by Ace Contributor
Solution
Re: Help with voicemail and contacting EE
Here are two alternative telephone numbers for EE, which you can call (if you wish) from a landline.
The local rate landline number is 020 7362 0200 or call for free on 0800 079 8586
6 REPLIES 6
by Ace Contributor
Solution
Thank you, I've tried both of these already and they are closed. I ideally wanted to sort it this evening. But looks unlikely!
Thanks for your suggestion however.
by Ace Contributor
Not sure of the opening hours of Live Chat, but here's the link to it (forgot to include this in my last post).
If Live Chat doesn't work, customer service are open again from 8 AM tomorrow.
http://ee.co.uk/help/getting-started/joining-ee/ee-live-chat
Thank you. Chats not popping up so assume they've finished for the evening. Ill call on one of the numbers you provided in the morning.
Thanks again
Thanks again
Hello there @Nbird,
Thanks for coming here.
You can access our technical support chat on our get in touch page.
This is available to EE personal pay monthly customers.
Or you can give us a call and we can get this looked into for you 🙂
Thanks, Leanne.
