by Lmullock
Every time I try making a call it come up call failed.
I’m away I. Barmonth and every time I try to make a call it comes up call failed. All my friends on EE are also having the same problem.
Are EE aware if there is a problem also 4G is very slow and nothing will work
Solution
Re: Every time I try making a call it come up call failed.
Solution
by Lmullock
My phone dose not need in locking it’s with EE. I can’t use 4G or make calls and everyone on this site on EE IS HAVING THE SAME PROBLEM
@Lmullock   The green ->THIS<- not the green wording below.      And what everyone on this site ?   Your the first I can see today having an issue.
Hi @Lmullock
Is this happening in one area?
Have you been able to check the link provided by @Chris_B to see if there is any known problems?
Katie 🙂
Recent solutions
