by Laylagrace21
Double texts
My iPhone 7 is sending texts to everyone twice I have re set the network and turned iMessage and FaceTime off and rebooted- Still no luck!? 😞
by Ace Contributor
Re: Double texts
Hello @Laylagrace21 how much signal do you have? When you have poor signal (1-2bars) or your device is cycling through 2/3/4G rapidly it may attempt to send the message more than once if it does not recognise the previous attempt was successful.
Re: Double texts
Hi @Laylagrace21
Thank you for coming to see us in community 🙂
I can see @tm90 has given you a great answer, has that helped you?
When these texts are sending twice, is it in the same area or happening at multiple locations?
Richard
