by Clare6 Investigator
Charges for using my ee mobile plan abroad
Hi, I am traveling to France and Belgium I have a EE plan, can I use my allowances whilst I am away please.  Thanks
Re: Charges for using my ee mobile plan abroad
@Clare6  Yes you can as you can now use your allowances while in the EU.  You will probably have to enable roaming on your account and you can do this via texting ROAMING to 150 and you can do this now if you wish.  But do it at least 24hours before you leave the UK so it’s active as soon as you get there.
You can can use up to 15GB of data each month as a fair usage policy if your plan has this or more that doesn’t mean you get 15GB if your plan has less.  Just a quick tip you'll probably need to restart your device to each now country you go to.
Hi @Clare6
Welcome to the community. 🙂
I see @Chris_B has expertly answered you here.
Have an amazing time. 😄
Thank you 😊
Thanks for your reply seems like my phone is already to go 😃
