by Noreeneleach
Can I disable WiFi on my sons phone and keep ability to use the phone.
by Noreeneleach
Re: Can I disable WiFi on my sons phone and keep ability to use the phone.
Thankyou ....I will try....
Sent from my iPhone
by Legend
Legend
Probably via an app you can. You will need to look in the play/apple store. You also maybe able to restrict usage via the data usage setting in Android.
