Highlighted
by Investigator
Call divert
I need to set up call divert on my phone. I have an iPhone SE pay as you go. I have tried the recommended *61* etc numbers but am getting an error message every time. Please can someone advise how I set this up? Thanks.
Highlighted
Solution
Re: Call divert
@Emily7790    Call divert/forwarding is not available to PAYG customers.
Hi @martyn413
8 REPLIES 8
Highlighted
by Star Contributor
Star Contributor
Re: Call divert
Hi @Emily7790
On your phone go into settings, phone, Call Forwarding then change the number.
Regards,
Martyn
Highlighted
by Investigator
Re: Call divert
Thanks Martyn. It is for work and I need to divert to one number if I am engaged and another number if my phone rings for a certain amount of time without me answering. So this call forwarding feature won’t work. I have been told I need to enter certain codes to my phone such as *61* followed by the phone number And then dial this in order to set this up but when I do this it says failed.
Highlighted
by Star Contributor
Star Contributor
Re: Call divert
Hi @Emily7790
I found this on the community:
All
Set: **21*destination#[SEND]
Cancel: ##21#[SEND]
Query: *#21#[SEND]
No Answer
Delay nn seconds: max 30 seconds, in 5 second increments
Set: **61*destination**nn#[SEND]
Cancel: ##61#[SEND]
Query: *#61#[SEND]
Unreachable
Set: **62*destination#[SEND]
Cancel: #62#[SEND]
Query: *#62#[SEND]
Busy
Set: **67*destination#[SEND]
Cancel: ##67#[SEND]
Query: *#67#[SEND]
Cancel All
##002#[SEND]
Let me know how you get on with these.
Many thanks,
Highlighted
by Investigator
Re: Call divert
Thanks so much for your help. This is what I have been trying and it just says unknown error every time.
Highlighted
by Star Contributor
Star Contributor
Re: Call divert
Hi @Emily7790
I don't suppose you have an old android phone do you?  Android phones have more call forwarding options.
Thanks,
Martyn
Highlighted
Solution
Re: Call divert
Hi @martyn413
Highlighted
by Star Contributor
Star Contributor
Re: Call divert
@Chris_B  I was getting to that point.  Hello.
@Emily7790  I'm sorry you had to go though all this for it to not work anyway.
Thanks,
Martyn
Highlighted
by Investigator
Re: Call divert
Okay. Thanks very much for your help and advice anyway!
Recent solutions
