by mrsshocks Contributor
BT Sports casts to my Sony smart tv but not my Samsung smart tv. Why?
BT Sports casts from my iPhone 7 to my Sony smart tv but not my Samsung smart tv. Why?
Solution
Re: BT Sports casts to my Sony smart tv but not my Samsung smart tv. Why?
@mrsshocks  It’s meant to cast through a Apple TV or Google chrome cast.”,  if you can cast directly to a tv without one of the above devices than you got lucky as it’s not meant to cast that way.
Solution
Many thanks for your reply.
Hi @mrsshocks,
Thanks for joining the community.
It sounds like your Sony TV has Chromecast built in. If your Samsung TV doesn't have this feature, you would need to connect it up to an Apple TV or Chromecast device to enable casting from your BT Sport app.
Hope this helps. Smiley Happy
Thanks for your reply. Very helpful!
No problem @mrsshocks Smiley Happy
