by dragonsplace Investigator
wifi calling
Does anyone have an up to date list of compatible phones with wifi calling. the last one I found was dated 2017.
thanks.
by Ace Contributor
Solution
Re: wifi calling
Hi @dragonsplace Only this one, updated in July 2018, so they haven't added the new iPhones yet either.
Any particular phone you are interested in knowing about? Someone may be able to confirm if it works.
7 REPLIES 7
by Ace Contributor
Solution
Re: wifi calling
Re: wifi calling
Thanks. A Samsung J3 2017 and a Samsung J5 2017
Re: wifi calling
Hi @dragonsplace
I've had a look into this. Samsung J5 (2017) phones bought directly from EE are compatible with WiFi calling.
The Samsung J3 (2017) isn't WiFi calling compatible.
Re: wifi calling
Thanks for that.
by Skilled Contributor
Skilled Contributor
Re: wifi calling
List of phones supporting WiFi calling is still not updated.
iPhone XS is missing 8 months after release so are other recent phones.
Re: wifi calling
Hi, and thanks.
My old Samsung (no Wi-Fi calling) finally died
So I've bought a Samsung J4 Plus, that has Wi-Fi calling.
Re: wifi calling
Hi @acdeag,
You can view an up to date list of compatible phones in EE WiFi Calling: All you need to know.
Hope this helps. 🙂
