by camillerbelg Investigator
where is quiet on pick up on the S8?
where can i find quiet on pick up on the S8?
by Brilliant Contributor
Solution
Re: Where do I find "Quiet on pick up " on S8
The phone doesn't have this feature.
What is happening though is the phone does have a feature to mute the ringing if you flip the phone over to be face down or if you put the palm of your hand over the front.
I suspect that when You are picking it up it is catching the sensors for the mute call on flipping over.
To turn this off you need to go to.
Settings > Advanced Features > Toggle Easy Mute.
13 REPLIES 13
Quiet on pick up seems to be on on my S8 I can't turn it off😭
Hello there @camillerbelg
Can you try going into Settings > Sounds and Display > Turn off this option.
Let me know how you get on 🙂
where can i find
Tanx for the response....
ok the phone has the heading   "Sounds and Vibration"....not
Display...and im not seeing (or recognizing) the relevant option 😞
Thanks for trying this @camillerbelg.
Let me see if one of our users can help you get this sorted.
@BrendonH are you by any chance using the S8?
Hope you can help if so 🙂
Solution
Re: where is quiet on pick up on the S8?
Thanks very much @BrendonH
Really appreciate your help.
Let us know if this works for you @camillerbelg
Thank u so much guys!!!
n the S8?
It did thanx  a million
Brilliant @camilerbelg
Thanks very much @BrendonH 🙂
by Charlie1948
New Member
This fixed my problem on a Samsung J5 too.
My problem was that the phone would silence as I took it out of my pocket and I am sure that it caused missed calls also.
Easy Mute = Quiet on pick-up!
