by gsxr1100l Investigator
when will i get android 6 on my galaxy note 4?
Hi all.
I am on ee pay monthly and running a samsung galaxy note 4.
I am wondering when i will get notifacation that android 6 is ready to be downloaded to my phone?
Cheers.
20 REPLIES 20
by Star Contributor
Star Contributor
Re: when will i get android 6 on my galaxy note 4?
Welcome to the community.
Have you manually checked for updates on your Note 4?
According to Samsung Mobile 6. 0.1 is available for the Galaxy Note 4 N910F on EE. Use Samsung PC software to install if OTA isn't available.
i have checked of update through both phone and keis
both say no udate avalable.
Enter *#1234# into the dialer and post the three sets of code.
AP:N910FXXU1BOG5
CP:N910FXXU1BOG5
CSC:N910FXXU1BOG5
Is it dual or single sim? Where did you get the the handset?
That firmware would suggest the firmware is generic UK do you should receive updates direct from Samsung.
After this length of time I would suggest downloading and installing via Odin from Sams mobile.
It is single sim
bought from internet factory unlocked.
e downloaded odin but no idea how to use it
sammobile wants me to pay for the download
Ok.
I have downloaded android 6 from sammobile and i have odin 3 v3  installed.
All i need now is help on how to upload it all to my note 4 please.
Thanks.
by Brilliant Contributor
Which online store did you purchase the phone from?
Ebay (brand new)
galaxy note 4 update to android 6
Hello,
Can someone walk me through how to update my samsung galaxy note 4 from android 5.1 to android 6.
I know the update is ready from EE but i never got it and my phone keeps saying my android 5.1 software is upto date which i know is not true.
Cheers Karl.
Re: galaxy note 4 update to android 6
 @gsxr1100l
Follow the instructions on Sam's mobile. If you are not confident in doing this upgrade then don't do it.
Do you mean this sam`s mobile site? (https://www.sammobile.com/)
If so i cannot see how to update tuition. (i am not very tech minded)
Cheers.
It tells you on thw download page for the firmware.
But if you are not text minded would wouldn' recommend it.
Have you done a factory reset to see if it'l then pick up the update.
Done a factory reset but still same, says update failed.
Saying update failed? That' new didn' or say up to date before?
my phone is running android 5.1.1
when i select update now in system updaes all i get is pricessing failed.
when i run samsung smart switch it says software upto date.
