by Skilled Contributor
Skilled Contributor
when will Galaxy Note 3 get Android 6
Does anyone know if EE will update Samsung Galaxy Note 3 to Android Marshmellow?
by Ace Contributor
Re: when will Galaxy Note 3 get Android 6
HI,
@Vennwood
I don't think this device able to get Android Marshmellow.
As this was released September 2013,
Android  5.0 (Lollipop) is final updates for this device.
Many Thanks
Skilled Contributor
Hi tahirmian,
you are probably right however there are posts on the Internet that suggest you can update.  I assume these are not "official" updates.
Thanks for your reply
