by Claradf77
wanting to keep my old phone number. Where do I do this on-line?
by Brilliant Contributor
Re: wanting to keep my old phone number. Where do I do this on-line?
Hello @Claradf77,
Welcome to the community,
Are you already with EE? If so, then you upgrade and you will keep your old number. If you needed a new SIM card, and you requested it from EE, then the number should be transferred automatically.
by Claradf77
thanks, however, I am moving from O2 to EE and have a PACS code.
According to the info in my phone box I should be able to enter these
details on the EE website but I am not seeing this option available
anywhere?
You will first need a temporary number ass you can see and then the second link is where you put your PAC code in doe transfer of your old number, hope this helps
http://ee.co.uk/help/getting-started/joining-ee/keeping-your-number
https://myaccount.ee.co.uk/keeping-your-number/
Hi @Claradf77
Welcome to the community. 🙂
Did you manage to get sorted following @Schockwave's advice and using the online form?
Chris 🙂
