by Stevo77
unable to set call forwarding to another number for pay monthly
When I go through the settings to forward my calls to another number I get an error and cannot switch it on.
Re: unable to set call forwarding to another number for pay monthly
Hi there @Stevo77
Welcome to the community.
Can I check, are you with us on a pay monthly account, or is this the number you want to divert calls too that is pay monthly?
What device are you using?
Also, are you forwarding calls to a UK mobile or landline number?
Leanne 🙂
by Stevo77
Hi
Hi @Stevo77
Thanks for coming back to me with this information 🙂
What error message do you get?
Leanne 🙂
by Ace Contributor
@Stevo77  You could try the divert codes,
*21*[phone number]#
I often find though if it doesn't work with the menus, it doesn't with with GSM codes and EE have to reset something in your account. (which cuts you off when they do it, so call from another phone if possible)
