by PeterTS
New Member
text message I get a red triangle not sent can anyone help
when I try to send a text message I get a red triangle with a white exclamation mark and the message is not sent, can anyone help.My phone is a Cubot.
Re: text message I get a red triangle not sent can anyone help
Go into messages - settings and look for message/service center number. For EE this should be +447958879879
Also if you are on PAYG make sure you are in credit.
Thanks,
Good Morning @PeterTS
Have you been able to send texts previously?
Can you make calls ok?
Thanks, Leanne 🙂
