by jennylouise Investigator
system ui alcatel pixi 4
I am getting the error message "sytem UI" cant be used, try to allow permissions. with the option to cancel or ok. Whichever I press I am then presented with a black screen, I have loaded the phone in safe mode and the message still appears.
Can anyone help?
Re: system ui alcatel pixi 4
Hi @jennylouise
There are many solutions on Google if you search.
Or just factory reset your phone.
Thanks i did search but results did not match my problem and solutions not possible i would factory reset but only have a black screen so unable to unless there is a way of doing this via owed and volume buttons
Hi and welcome to the community, @jennylouise. 🙂
Please try the steps below:
Step Action
1 Please turn off the device by holding down the Power key for a short while.
2
When turned off, press and hold the Volume Up + Power button simultaneously for a couple of seconds.
3
Please release all keys as soon as the ALCATEL logo appears.
4
Next, choose 'wipe data/factory reset'
5
Use the Volume Down to navigate and the Power button to confirm.
Let me know if that helps.
Chris 🙂
Unfortunately it didn't luckily it's only a spare phone I was using whilst mine is away for repair.
